My remote seems to have issues maintaining a stable connection to the dock. I have the dock connected via ethernet. Does anyone have any tips to resolve this connection stability issue?
What network system do you have? Try using IP instead of name for connection to dock.
I’m on IP. I suspect this is a sleep/waking issue. Have you experienced anything similar?
I hardly use a dock only for 2 of my activities. If the remote sleeps on the table it can take some seconds until she is in the WiFi again and then also some seconds before all IP intergrations are connected again.
I am having the same problem. You mentioned you use the remote for activities - how do you setup this. If I do not select a Dock the remote displays that the is no IR device. I have two Docks and the dropdown is ““, “Dock 1”, “Dock"2”.
Do you have an advice?
Settings, development, preview features.
@HarmonyFan: Thanx a lot, found it.
And what should I allow or block there?
