Dock 3 Status LED not working/missing?
I see talk of a dock status LED for charging, learning, etc. I also see an LED brightness control in the dock settings. However, I see no LED on the dock under any circumstance. The LCD screen works fine but no LED. Not sure if this is a HW or SW issue. Anyone else experiencing this? Tips?
Goto the dock settings, click identify then the led will blink red/green. It is in the front but on the bottom.
Thanks for the reply but yes, I have tried this. There is no LED. Attempted at maximum brightness in near total darkness observing from every angle. It’s not there. Maybe I have a defective dock. Doesn’t seem entirely critical but was just curious if I was alone here.
Did you have connection to the dock when you tried it?
Yeah, it doesn’t work. (or isn’t there). I’m not worried about this for now. I ordered another dock for charging so it will be interesting to see if the LED works when I get it. Everything seems fully functional. Just no LED.
