Hello,
The Dock 3 mentions “compatible rs232 devices”. Will it be possible to define devices/actions?
Can the device work as a tcp/udp to rs232 bridge?
Meaning: it receives a tcp or udp packet and sends out an rs232 command as a result? And vice versa (rs 232 input → tcp/udp output)?
Second question: can it use input from an rs232 port to show something on the screen? (e.g. the current source selected on an amplifier)
Thanks,
Jörg
I‘m interested in similar question.
Trinnov Altitude 32 can receive RS232 commands, (how) would it be possible to connect the R2/R3 (dock) to the Atitude to send commands like power on/off etc.?
No comments on this? It could be useful to connect e.g. an amplifier to have discrete control and - if possible - show the status.
I am hoping to implement such a capability eventually. I have a Parasound P7 preamp for which there are RS232 commands to control (human readable ASCII) and status responses. I would like, for example, to be able to adjust the volume and have a state aware update on a volume display on the remote. This should be possible, especially on the R3 that has RS232 in/out. But certain software pieces don’t exist yet, such as GUI widgets to display analog status. Meanwhile, IR control is working fine. But the front panel displays aren’t very visible from where I sit.
I would love that, yes.
Fast Forward 17 months, still no RS232 on R3 Dock.
The Dev team are wasting time on non-roadmap items like Sonos, Screen / Ambient lighting, and other side quests.
There are Six (6) weeks left in 2025.
Roadmap items still not delivered, six weeks to go, what is the delivery date for each of these?
- Voice support for Home Assistant Assist
- Local voice control for entity commands
- Speaker groups in supported integrations
- RS232 support in new dock
- IR learning on the remote
- OpenHAB integration
- IKEA Trådfri integration
- Extending voice support on the remote
- Adding voice support in Dock 3
- Additional support for more home automation systems
- ioBroker integration
- Hubitat integration
Forget the dates on the roadmap. It was never really accurate in the first place. Think of it as a priority list for new bigger features. Shipping rewards took longer than expected and there were also delays caused by a 3rd party vendor of the WiFi chip firmware.
As stated in the last Kickstarter update they will now focus more on software as almost all rewards have been shipped.
Sorry for request: is the RS232 support via dock/R3 still missing? Thanks![]()
Yes, you can subscribe to the GitHub feature request: Implement RS232 communication · Issue #4 · unfoldedcircle/ucd3-firmware · GitHub
Thanks @kennymc.c
