I pickup up my remote from the dock and noticed it was dead… And the dock was not charging… I unplugged the dock and re-plugged it in after 10 seconds nothing happend. I did not get the usual start up animation nor the ethernet lights flashing… It is completly dead. Is there a way to fix this? Anyone else experince this?
Think you will need to send it back. I would contact support.
What firmware has the Dock? 0.8.2 should be latest version. Earlier versions had a charging bug. Are you using the included cable? Have you tried a different charger? Can you ping the dock ip? Have you tried to reset the dock?
I believe it was running the latest version… I have 2 docks and I just ran the 0.10.4. but the one that is dead I cannot access .. it doesn’t seem to power on… So I cannot verify its firmware. I tried other cables and power sources. It it seems you need to have power to reset the device…
Yes I have contacted their support hopefully I get a reply back…
I had the same issue. My dock was dead and all recommended test and using POE supply was not successful. So at the end I returned the dock on RMA, but be prepared for a super long repair time. My dock is still not back.
I too have a dead dock, no LCD, no light, @lutz can we setup an RMA? An email was sent to 8/4
Will anyone from unfolded help me?
I have emailed and posted here. My dock has been dead since 3 months of receipt.
This ist just a community forum managed by UC. Mail and Github are the only official support channels. For hardware problems you have to mail them.
The main support employe left the company recently and a new one just started and probably has to catch up with a lot of unanswered issues.
I’ve had the same problem since today. The dock is simply dead. I’ve contacted support, too, but I certainly don’t want to wait three months! Does anyone here have a working dock for the Remote 3 for sale? I’d be happy to have it shipped to Germany.
