I face a new problem since the firmware update to 2.9.2.
Already three times during the last week the display turned pale. So I can still use it, but all the colors look weird and pale. The only solution is rebooting the r3.
Interlaced lines that can make the display look like it’s tinted are a known issue on the R3 and have the same cause as the ghost touches. They are a software issue while initializing the display and not a hardware issue.
UC is working on fixing these issues but they are hard to debug. Restarting the remote is the only workaround right now.
OK, thanks for the feedback. Next time this issue occurs, I will make a photo.
I hope they come around with a solution soon, because here in my family I’m already struggling keeping this remote in use. Too many inconvenient things. Some of them of course, because I cannot find the time to solve each and every tiny problem. And there are a lot of them.
Looks different than the photos from the linked issue. Maybe you should contact support and ask them if this could have the same cause or if it’s an actual hardware defect. But I suspect it might just be another variant of the display intilization issue thats already causing 2 different display/touchscreen issues.
I found out if I do not restart the remote, from time to time it switches back to the normal color mode. This occurs if the remote is just lying on the table and wakes up. Then I can see that the colors turned back to normal. I thought the last update should solved the issue with the frequent unwanted wake ups. Wasn’t it like this?
I have sent a message to the support and described the problem.
Where did you read that the unwanted wake ups were fixed?
If the issue occurs after wake up then it could be connected to the known artifacts issue. As you contacted support they should be able to analyse this further.
It’s still an known problem with 2.9.3 and now finally included in the known issues section of the release notes.
Flickering might be new but maybe also related if it happens after wakeup but only UC support can confirm this. You could add a video to the GitHub issue linked above.
A mod on Discord wrote that UC is in contact with the display manufacurer but the process is slow similar to the WiFi chip vendor.
I have sent a video to the UC support. Now I also had the “green-lines-display”. The remote is almost not usable anymore as the colors change within minutes. Really frustrating, at the moment.
