Display turns on
Since the second-to-last firmware update, the remote control’s display turns on regularly. Every 1-2 Minute.
What can I do? Because of this, the battery drains very quickly.
Try to turn off the Keep WiFi Connected in Standby setting under power saving. This might be caused by another device/router waking up the remote via Wake on Lan. This setting is also known to cause random wake ups by the remote itself. As it’s hard to debug the only workaround right now is to turn this setting off.
