My remote is ‘seeing’ the AVR via the Denon integration, but there are no functions exposed. Can someone point me in the right direction?
It’s your lucky day! I’m running an SR6014 and I am also using the Denon integration. My view and yours, from this screen, look the same:
When I go to configure an activity, I am presented with the option to select my different equipment - for now I’ll just make a dummy activity with the IP-based control:
On the new activity screen, I can select from a limited set of commands and drag them into the order:
I can also use certain elements in the UI
And create a button
The Denon unit has control parity between IR and IP: you can transmit IR controls over telnet, so I’m hoping that we’ll be able to send some more commands soon.
Thanks so much for this thorough explanation! I’ll definitely have another go at it later this week.
