Hello. I bought a Denon RCD-N12 as a radio tuner. I currently have an integration with my Denon x3800 in Remote 3. I wanted to add the Denon RCD-N12 as a new integration, but when I try, it doesn’t show up in Remote 3. The only options are my old Denon x3800 AVR. So I decided to add it via IR. I even had everything ready, but I ran into a problem. I have about 30 radio stations stored in my memory. I decided I’d like to create shortcuts to each station on my Remote 3 display using the radio station icon. The problem is that while I could probably do it for numbers 1 to 9, everything above that requires a sequence of two button clicks. Is this feasible? For example, I need to execute the following command: 1 + 500ms delay + 2 to get 12, which I can save in Remote 3’s activities.
Try IR sequence with DIGIT_1, DIGIT_2,RETURN
But how do I set up such a sequence in the web interface? Where is this option?
Search for IR sequence as a command
Can you give me the path to this IR sequence? I don’t see it anywhere.
What do you mean by path? It’s in the same list as all other commands
When I create and read commands from the original remote, I don’t see the option to set up a sequence. Webinterface/entities/Denon Radio/Settings I’ve only seen sequences in Activities & Macro, but that’s a sequence for turning on all the equipment, not a single button.
The send command/send command sequence commands are only available inside activities or macros.
I’m not sure if I understand this correctly. Do you mean I need to create a macro and then assign it to a button in the activities? I created a macro like this: 1 + 500ms delay + 0. This should trigger channel 10. However, I don’t see an option in the activities in the LCD interface to add a macro to a button.
I think I know what’s going on. In WEB Interface / Activities & Macro / Radio / User Interface / I’m editing a button and I need to change it from IR Command to IR Sequence. Here’s the problem. In the Commands option, what should I enter? For example, should I enter 1, 2 to get 12? Below is the delay. How does that relate to this? If 3 steps are to be performed, is there a delay for all of them?
I’ve already figured it out. I need to enter 1, 2 without spaces to get 12.
You just separate each command (written like they are shown in the command list) with a comma. I’m not sure if delays are possible with ir sequences. That might need a macro.
To be able to map the macro inside an activity you first need to add the macro to that activity. Then when you search for the macro name inside the commands list when mapping or adding a button it should show up with an execute command
