Would be nice if we could customize the built-in Integrations.
I want to add aditional scripts (buttons) in the AppleTV integration.
Also I want to be able to change the volume control to an ir soundbar.
I know that this is already possible using activities but then I loose the nice picture and also the availability to switch the apps (ok I can add these as custom buttons).
For the apps it would be nice if I could remove apps not required from the selection.
