Is it possible to skip the activities page or have activities as tiles. I only use an Apple TV activities and shortcuts to different steaming channels, Netflix , Hulu , etc.I hv to start Apple TV activity 1st then goes to a media age with short cuts- I would like to climate the 1st page.
I do not understand media age and climate.
I assume you want to start an app directly. If yes add a delay after power on off Apple TV and the the command input/source with the app you want. I use it this way.
excuse my poor typing skills on my phone. I meant activity page and eliminate. I would like the 1sr page to be all shortcuts in tile form. It seems that you have to start an activity 1sr and then setup the user interface.
Not in tile form but you can create macros with all commands to start an app and put them on your main/profile pages instead of activities. If you also have the Apple TV on the same page some controls like volume also work outside of activities. But this is just a very weird workaround and not recommend. Just use activities and there you can map any page and button just like you want.
When I use an activity, I see a folder icon at the top of my page, the name of the activity and, above all, an ‘X’ button that’s easy to press by mistake. That’s not something I want. Can I stop that from happening?
No, the activity top bar is a system ui component and can’t be hidden. From there you can exit the activity without powering it off, correct entity states or go to the ui of an included entity. The icon you see should be the one from the activity.
Thanks for the info. But what about Discord by Ralf Biedermann? That looks just as I’d like it to.
That screenshot is from the web configurator. The configurator is not using the same ui as the actual remote.
A new ui, that will probably look similar to the one from the configurator and the screenshots from the UC website, is planned since few years but development has been paused because of other more important WiFi bug fixes. But according to a recent Discord post from a developer development has been picked up again but priority is still making WiFi more stable.
That sounds good. Thank you
