Hi everyone,
I’d like to share my new custom integration for the Unfolded Circle Remote 3:
Music Play
Music Play brings music browsing and playback control to the Remote 3 through a local Music Assistant server.
The project originally started because I wanted a convenient way to control Deezer directly from my Remote 3, including browsing my music instead of only having basic Play/Pause controls.
The current version has grown into a more generic Music Assistant integration, so it is not limited to Deezer. Other music providers configured in Music Assistant can be used as well, depending on their capabilities.
What it can do
The integration currently supports:
Now Playing with title, artist and album
Album artwork
Play / Pause
Stop
Previous track
Next track
Seeking within the current track
Shuffle
Repeat
Volume and mute
Browse playlists
Browse albums
Browse artists
Browse library tracks
Search for music
Start individual tracks directly from playlists or search results
Play Now / Play Next / Add to Queue
Browse the current playback queue
Select and control Music Assistant playback devices
Physical Remote 3 media/navigation button support
Dynamic playback status updates
Automatic reconnect to Music Assistant
No Home Assistant required
An important goal of the project was to avoid making Home Assistant a mandatory part of the setup.
The integration communicates directly with Music Assistant.
For example, my own setup is:
Remote 3 → Music Play → Music Assistant → Deezer → Denon AVC-X4800H / HEOS
Music Assistant handles the music provider and the actual playback device, while Music Play provides the Remote 3 interface and controls.
Remote 3 interface
The integration uses a native Media Player entity on the Remote 3.
Besides the touchscreen controls, physical media and navigation buttons can also be used for playback control.
The goal is to make the Remote 3 feel like a proper music remote rather than just exposing a few commands.
Search
Music can be searched directly from the Remote.
For more specific searches, Music Assistant also supports queries such as:
Artist - Title
This is useful when several tracks have the same or similar names.
Requirements
You need:
- Unfolded Circle Remote 3
- A local Music Assistant server
- A music provider configured in Music Assistant
- A compatible playback device configured in Music Assistant
- A Music Assistant Long-Lived Access Token
I developed and tested the integration primarily with:
- Deezer
- Music Assistant
- Denon AVC-X4800H via HEOS
Other Music Assistant providers and players may work as well, but I haven’t tested every possible combination.
Download
The current public release is:
Music Play v0.2.6
GitHub:
Open Releases and download:
uc-intg-music_play-0.2.6-aarch64.tar.gz
Please do not use GitHub’s automatically generated “Source code” ZIP/TAR files for installation. The Remote 3 requires the packaged AArch64 integration archive from the release assets.
Current status
This is the first public release.
The integration is already usable, but I still consider it an actively developed community project. There are several areas I’d like to improve further, especially the music browsing/search experience, physical button mappings and the overall Now Playing experience.
Feedback, testing and bug reports are very welcome – particularly if you’re using different Music Assistant providers or playback devices.
If something doesn’t work, please include your Remote 3 integration logs and information about your Music Assistant player/provider where possible.
Enjoy! ![]()
