Creating empty IR device/entity
Hello,
I would like to create a new entity as IR-device, where I can train all IR-codes by myself.
How can I create an empty IR-entity?
So far I always have to select an existing device from the search-list, but then the IR-codes will not fit. Of course I can overwrite existing codes, but as I might not have codes for all existing commands, the entity is always providing these (not needed) commands , when creating an activity etc.
I haven‘t found a possibility to delete commands not being needed from an existing device/entity.
If you add an entity and select IR then there is a checkbox to create an empty entity with create blank.
Oh, I am sorry, I haven‘t noticed this.
That seems to Bev a general issue (for me at least): it is quite hard to notice in some dialogues that there is a need of scrolling.
