Connection to Dock Problem
There are many times that i get the error message “connection to dock not established”. My dock is connected via Ethernet in manual mode and it has a static IP address. Anyone have any ideas on how to fix this?
I often get this as well. I haven’t figured out yet if it is the dock that is not connected or I’d}f the issue is with the remote.
By static IP you are also referring to setting a custom url in the Dock settings? Make sure to do this if you’re having connection problems: https://support.unfoldedcircle.com/hc/en-us/articles/20018912602524-Manually-add-a-Dock-in-the-Web-Configurator
@kennymc.c Just curious - In my case, it finds the dock 9 out of 10 times. It’s just an occasional issue. Would the manual connection help in this scenario, or is that only if there is a more persistent problem?
It can’t hurt as, mdns can be finicky.
I just removed my docks and re-added manually. I’ll post back in a few days to let you know if I’m still getting the connection issue. Thanks!
Np. Good luck
What really is the point of the dock? I have connected it through ethernet to ensure a stable connection, but the R3 still does all the heavy lifting and ignores the dock and tries to connect per WiFi directly to the router. Why not connect to the dock, which is much closer and has better connectivity?
The point of the dock is to provide infra red connections and extend the remote reach. Think about it as if you have your devices outside of your media room (such as my setup, non of my devices are in the theater room, they are in a rack outside the room in a dedicated server room). Then think about if there is a device that doesn’t have an IP or an existing integration but it does have infra red, that’s where the dock come in. Logitech harmony had the brain on the dock, unfolded kept the brain directly on the remote from what I assume is privacy reasons as well as hardware costs / power reasons. Hope that answer your question.
Welp, this morning I got the dreaded dock connection error again. I have 2 docks - One connected via wifi and the other ethernet POE. Here are my troubleshooting steps:
  1. Restarted remote. Did not work.
  2. Restarted wifi dock and remote. Did not work.
  3. Restarted POE dock and remote. This worked.
I would have guessed that the wifi dock would be the one with the connection issue, but based on my testing it looks like it was the POE. Logs below. Any thoughts?
2026-01-09 12:25:36.680777 +00:00	core	NOTICE	Standby mode is inhibited by: [“Active activity ‘Watch TV’”]
2026-01-09 12:23:44.676546 +00:00	core	NOTICE	Next OTA system update check: 2026-01-10T03:38:29-05:00
2026-01-09 12:21:34.389542 +00:00	core	NOTICE	Changed battery status: 84% Discharging, 3944mV, charger: false
2026-01-09 12:21:06.685600 +00:00	core	NOTICE	Setting rgb button backlight to: (0, 0, 0)
2026-01-09 12:21:06.684453 +00:00	core	NOTICE	Enter low-power mode: standby in 270s
2026-01-09 12:20:50.682749 +00:00	core	NOTICE	Setting rgb button backlight to: (0, 0, 0)
2026-01-09 12:20:50.681450 +00:00	core	NOTICE	Enter idle mode: standby in 285s
2026-01-09 12:20:15.709692 +00:00	core	NOTICE	[uc.main.d1fadf6d-3eea-4223-b48b-7849575d9709] activity ‘Watch TV’ is running and preventing device standby
2026-01-09 12:20:15.708356 +00:00	core	NOTICE	[Watch TV] activity finished
2026-01-09 12:20:15.707724 +00:00	core	NOTICE	Removed standby inhibitor: macro ‘Audio Mode: TV’ (run) (max 65s)
2026-01-09 12:20:15.707114 +00:00	core	NOTICE	[Audio Mode: TV] macro finished
2026-01-09 12:20:15.698653 +00:00	core	NOTICE	[Audio Mode: TV] macro command: hass.main.input_button.home_theater_scene_tv:button.push
2026-01-09 12:20:15.697961 +00:00	core	NOTICE	Added standby inhibitor: macro ‘Audio Mode: TV’ (run) (max 65s)
2026-01-09 12:20:15.697139 +00:00	core	NOTICE	Started macro ‘Audio Mode: TV’ (uc.main.2847c7be-5220-43c2-b819-976b4a164b09), waiting for completion or timeout (60s)
2026-01-09 12:20:15.686304 +00:00	core	NOTICE	[Watch TV] activity command: uc.main.2847c7be-5220-43c2-b819-976b4a164b09:macro.run
2026-01-09 12:20:13.690051 +00:00	core	NOTICE	[Watch TV] activity delay: 2000 ms
2026-01-09 12:20:12.653469 +00:00	core	NOTICE	[Watch TV] activity command: uc_appletv_driver.main.DE:00:38:81:5F:FC:TOP_MENU
2026-01-09 12:20:09.652281 +00:00	core	NOTICE	[Watch TV] activity delay: 3000 ms
2026-01-09 12:20:09.630159 +00:00	core	NOTICE	[Watch TV] activity command: uc_appletv_driver.main.DE:00:38:81:5F:FC:media_player.on
2026-01-09 12:20:07.628417 +00:00	core	NOTICE	[Watch TV] activity delay: 2000 ms
2026-01-09 12:20:07.624842 +00:00	core	NOTICE	[custom-f06b11] Removing expired open request: 1
2026-01-09 12:20:07.378359 +00:00	core	NOTICE	[Watch TV] activity command: uc.main.9b0f2e66-f921-4197-8149-6f267061d082:remote.on
2026-01-09 12:20:05.836720 +00:00	core	NOTICE	[Watch TV] activity command: uc.main.7658f169-56b0-4196-9053-79e12dc7b262:POWER_ON
2026-01-09 12:20:05.836559 +00:00	core	NOTICE	Added standby inhibitor: Active activity ‘Watch TV’
2026-01-09 12:20:05.836350 +00:00	core	NOTICE	Started activity ‘Watch TV’ (uc.main.d1fadf6d-3eea-4223-b48b-7849575d9709) with timeout of 60s
2026-01-09 12:20:05.835087 +00:00	core	NOTICE	Starting activity ‘Watch TV’ (uc.main.d1fadf6d-3eea-4223-b48b-7849575d9709) in activity group: ‘Activities’ (87b74b3a-5318-4809-bbb5-5ddbc8aa49af)
2026-01-09 12:20:04.668666 +00:00	core	NOTICE	Setting rgb button backlight to: (255, 255, 255)
2026-01-09 12:20:04.667264 +00:00	core	NOTICE	Enter normal mode: standby in 300s
2026-01-09 12:19:14.687784 +00:00	core	NOTICE	Setting rgb button backlight to: (0, 0, 0)
2026-01-09 12:19:14.686507 +00:00	core	NOTICE	Enter low-power mode: standby in 270s
2026-01-09 12:18:59.681033 +00:00	core	NOTICE	Setting rgb button backlight to: (0, 0, 0)
2026-01-09 12:18:59.680103 +00:00	core	NOTICE	Enter idle mode: standby in 285s
2026-01-09 12:18:57.343865 +00:00	core	NOTICE	Sent get_entity_states to uc_appletv_driver: Ok(())
2026-01-09 12:18:56.963724 +00:00	core	NOTICE	Sent get_entity_states to uc_appletv_driver: Ok(())
2026-01-09 12:18:56.945718 +00:00	core	NOTICE	[uc_appletv_driver] SessionAuthenticated msg
2026-01-09 12:18:56.945571 +00:00	core	NOTICE	[uc_appletv_driver] Session state change: Authenticated
2026-01-09 12:18:56.942654 +00:00	core	NOTICE	[uc_appletv_driver] Session became active: sending subscribe_events, get_driver_version, connect
2026-01-09 12:18:56.942335 +00:00	core	NOTICE	[uc_appletv_driver] SessionAuthenticated msg
2026-01-09 12:18:56.942193 +00:00	core	NOTICE	[uc_appletv_driver] Session state change: Authenticated
2026-01-09 12:18:56.939606 +00:00	core	NOTICE	[uc_appletv_driver] Connected to: ws://127.0.0.1:8097
2026-01-09 12:18:53.796489 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:52.005383 +00:00	core	NOTICE	Sent get_entity_states to yamaha_avr_driver: Ok(())
2026-01-09 12:18:51.741045 +00:00	core	NOTICE	Sent get_entity_states to yamaha_avr_driver: Ok(())
2026-01-09 12:18:51.698737 +00:00	core	NOTICE	[yamaha_avr_driver] SessionAuthenticated msg
2026-01-09 12:18:51.698463 +00:00	core	NOTICE	[yamaha_avr_driver] Session state change: Authenticated
2026-01-09 12:18:51.693124 +00:00	core	NOTICE	[yamaha_avr_driver] Session became active: sending subscribe_events, get_driver_version, connect
2026-01-09 12:18:51.692568 +00:00	core	NOTICE	[yamaha_avr_driver] SessionAuthenticated msg
2026-01-09 12:18:51.692443 +00:00	core	NOTICE	[yamaha_avr_driver] Session state change: Authenticated
2026-01-09 12:18:51.691321 +00:00	core	NOTICE	[yamaha_avr_driver] Connected to: ws://127.0.0.1:9001
2026-01-09 12:18:51.387123 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:50.574613 +00:00	core	ERROR	[yamaha_avr_driver] Error connecting to driver ws://127.0.0.1:9001: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:49.724334 +00:00	core	ERROR	[yamaha_avr_driver] Error connecting to driver ws://127.0.0.1:9001: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:49.530904 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:49.333191 +00:00	core	NOTICE	Added standby inhibitor: charger
2026-01-09 12:18:49.332744 +00:00	core	NOTICE	Changed battery status: 85% Discharging, 3856mV, charger: false
2026-01-09 12:18:49.081405 +00:00	core	ERROR	[yamaha_avr_driver] Error connecting to driver ws://127.0.0.1:9001: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:48.576851 +00:00	core	ERROR	Error starting custom integration session: Failed to connect to host: Connection refused (os error 111)
2026-01-09 12:18:48.576195 +00:00	core	ERROR	[yamaha_avr_driver] Error connecting to driver ws://127.0.0.1:9001: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:48.101129 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:47.887362 +00:00	core	NOTICE	BtDaemonStatus { status: Working, hci_log: true, log_level: Debug, connections: 0, max_connections: 1, paired_profiles: 0, active_profile: 0, advertising: true, advertising_name: “Remote3 6715FF”, version: “0.6.0” }
2026-01-09 12:18:47.883175 +00:00	core	NOTICE	[BT] Scan mode: discoverable=false, connectable=false
2026-01-09 12:18:47.014933 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:46.941339 +00:00	core	NOTICE	BtDaemonStatus { status: Initializing, hci_log: true, log_level: Debug, connections: 0, max_connections: 1, paired_profiles: 0, active_profile: 0, advertising: true, advertising_name: “Remote3 000000”, version: “0.6.0” }
2026-01-09 12:18:46.931679 +00:00	core	NOTICE	Connected to BT daemon: 127.0.0.1:13333
2026-01-09 12:18:46.929709 +00:00	core	NOTICE	Restarting BT daemon client, enabled=true
2026-01-09 12:18:46.480083 +00:00	core	NOTICE	Created Dock IR emitter: dock_id=custom-b9e17f, name=‘Unfolded Circle Charging Dock’, model=UCD3, active=true, port_mask=0
2026-01-09 12:18:46.357206 +00:00	core	NOTICE	Created Dock IR emitter: dock_id=custom-b9e17f, name=‘Unfolded Circle Charging Dock’, model=UCD3, active=true, port_mask=0
2026-01-09 12:18:46.347510 +00:00	core	WARN	[custom-b9e17f] Can’t handle dock Authenticated command in state: Active
2026-01-09 12:18:46.346937 +00:00	core	WARN	[custom-b9e17f] No transition for: state=Active, event=Authenticated
2026-01-09 12:18:46.343692 +00:00	core	NOTICE	[custom-b9e17f] Authenticated (features=3)
2026-01-09 12:18:46.337229 +00:00	core	NOTICE	Sent get_entity_states to intg_manager_driver: Ok(())
2026-01-09 12:18:46.317666 +00:00	core	NOTICE	[custom-b9e17f] Authenticated (features=3)
2026-01-09 12:18:46.310468 +00:00	core	NOTICE	Created Dock IR emitter: dock_id=custom-f06b11, name=‘Unfolded Circle Dock (Cabinet)’, model=UCD3, active=true, port_mask=0
2026-01-09 12:18:46.310355 +00:00	core	NOTICE	[intg_manager_driver] Session became active: sending subscribe_events, get_driver_version, connect
2026-01-09 12:18:46.310143 +00:00	core	NOTICE	[intg_manager_driver] SessionAuthenticated msg
2026-01-09 12:18:46.309983 +00:00	core	NOTICE	[intg_manager_driver] Session state change: Authenticated
2026-01-09 12:18:46.309626 +00:00	core	NOTICE	[intg_manager_driver] SessionAuthenticated msg
2026-01-09 12:18:46.309507 +00:00	core	NOTICE	[intg_manager_driver] Session state change: Authenticated
2026-01-09 12:18:46.308447 +00:00	core	NOTICE	[intg_manager_driver] Connected to: ws://192.168.1.200:9090/
2026-01-09 12:18:46.305706 +00:00	core	NOTICE	Sent get_entity_states to hass: Ok(())
2026-01-09 12:18:46.305213 +00:00	core	WARN	[custom-b9e17f] Can’t handle dock Connected command in state: Connected
2026-01-09 12:18:46.304779 +00:00	core	WARN	[custom-b9e17f] No transition for: state=Connected, event=Connected
2026-01-09 12:18:46.304588 +00:00	core	NOTICE	[custom-b9e17f] Connected to: ws://192.168.1.191/ws
2026-01-09 12:18:46.275652 +00:00	core	NOTICE	[custom-b9e17f] Connected to: ws://192.168.1.191/ws
2026-01-09 12:18:46.253656 +00:00	core	NOTICE	Sent get_entity_states to hass: Ok(())
2026-01-09 12:18:46.236439 +00:00	core	WARN	[custom-f06b11] Can’t handle dock Authenticated command in state: Active
2026-01-09 12:18:47.086091 +00:00	core	WARN	[custom-f06b11] No transition for: state=Active, event=Authenticated
2026-01-09 12:18:47.085900 +00:00	core	NOTICE	[custom-f06b11] Authenticated (features=3)
2026-01-09 12:18:47.068248 +00:00	core	WARN	[custom-f06b11] Cannot send message, connection not yet authenticated!
2026-01-09 12:18:47.057091 +00:00	core	NOTICE	[custom-f06b11] Authenticated (features=3)
2026-01-09 12:18:47.042766 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:46.998969 +00:00	core	WARN	[custom-f06b11] Can’t handle dock Connected command in state: Connected
2026-01-09 12:18:46.998595 +00:00	core	WARN	[custom-f06b11] No transition for: state=Connected, event=Connected
2026-01-09 12:18:46.998229 +00:00	core	NOTICE	[custom-f06b11] Connected to: ws://192.168.1.192/ws
2026-01-09 12:18:46.986157 +00:00	core	NOTICE	[custom-f06b11] Connected to: ws://192.168.1.192/ws
2026-01-09 12:18:46.887080 +00:00	core	NOTICE	Ignoring connected event from WiFi driver, using operational state instead
2026-01-09 12:18:46.875714 +00:00	core	NOTICE	[custom-b9e17f] WiFi connected: connecting dock
2026-01-09 12:18:46.875534 +00:00	core	NOTICE	[custom-f06b11] WiFi connected: connecting dock
2026-01-09 12:18:46.871106 +00:00	core	NOTICE	WiFi interface is up and routable, sending connected event
2026-01-09 12:18:46.866783 +00:00	core	NOTICE	Network changed: link_name: wlan0, operational_state: routable, address_state: routable, ipv4_address_state: routable, online_state: online
2026-01-09 12:18:46.810097 +00:00	core	ERROR	Cannot connect to BT daemon: I/O error. Reconnecting in 1.00550378s
2026-01-09 12:18:46.809491 +00:00	core	NOTICE	Restarting BT daemon client, enabled=true
2026-01-09 12:18:46.804768 +00:00	core	NOTICE	Network changed: link_name: wlan0, operational_state: carrier, carrier_state: carrier
2026-01-09 12:18:46.773032 +00:00	core	NOTICE	Network changed: link_name: wlan0, operational_state: dormant, carrier_state: dormant
2026-01-09 12:18:46.474630 +00:00	core	ERROR	[intg_manager_driver] Error connecting to driver ws://192.168.1.200:9090/: ServiceUnavailable(“Failed to connect to host: Network is unreachable (os error 101)”)
2026-01-09 12:18:46.382649 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:46.327816 +00:00	core	ERROR	Cannot connect to BT daemon: I/O error. Reconnecting in 476.621888ms
2026-01-09 12:18:46.327284 +00:00	core	NOTICE	Restarting BT daemon client, enabled=true
2026-01-09 12:18:46.211278 +00:00	core	NOTICE	[custom-b9e17f] Reconnecting in: 650ms
2026-01-09 12:18:46.210986 +00:00	core	ERROR	[custom-b9e17f] Error connecting to dock ws://192.168.1.191/ws: ServiceUnavailable(“Failed to connect to host: Network is unreachable (os error 101)”)
2026-01-09 12:18:46.206785 +00:00	core	NOTICE	[custom-f06b11] Reconnecting in: 650ms
2026-01-09 12:18:46.206130 +00:00	core	ERROR	[custom-f06b11] Error connecting to dock ws://192.168.1.192/ws: ServiceUnavailable(“Failed to connect to host: Network is unreachable (os error 101)”)
2026-01-09 12:18:46.026418 +00:00	core	NOTICE	  uccore : PWD=/opt/uc/data ; USER=root ; COMMAND=/usr/bin/systemctl start custom-intg@yamaha_avr_driver
2026-01-09 12:18:45.978357 +00:00	core	NOTICE	Execute system command: StartCustomIntegration(“yamaha_avr_driver”, Some(“custom-intg@yamaha_avr_driver”))
2026-01-09 12:18:45.971931 +00:00	core	ERROR	[intg_manager_driver] Error connecting to driver ws://192.168.1.200:9090/: ServiceUnavailable(“Failed to connect to host: Network is unreachable (os error 101)”)
2026-01-09 12:18:45.970632 +00:00	core	NOTICE	Not starting driver ‘uc_roku_driver’: no configured instances
2026-01-09 12:18:45.962185 +00:00	core	NOTICE	Not starting driver ‘uc_androidtv_driver’: no configured instances
2026-01-09 12:18:45.962079 +00:00	core	NOTICE	Not starting driver ‘uc_bo_driver’: no configured instances
2026-01-09 12:18:45.961963 +00:00	core	NOTICE	Not starting driver ‘uc_gc_driver’: no configured instances
2026-01-09 12:18:45.959581 +00:00	core	NOTICE	Not starting driver ‘uc_denon_driver’: no configured instances
2026-01-09 12:18:45.941845 +00:00	core	NOTICE	[hass] Session became active: sending subscribe_events, get_driver_version, connect
2026-01-09 12:18:45.941440 +00:00	core	NOTICE	[hass] SessionAuthenticated msg
2026-01-09 12:18:45.940546 +00:00	core	NOTICE	[hass] Session state change: Authenticated
2026-01-09 12:18:45.935522 +00:00	core	NOTICE	[hass] SessionAuthenticated msg
2026-01-09 12:18:45.935340 +00:00	core	NOTICE	[hass] Session state change: Authenticated
2026-01-09 12:18:45.932175 +00:00	core	NOTICE	[hass] Connected to: ws://127.0.0.1:8000/ws
2026-01-09 12:18:45.907616 +00:00	core	NOTICE	Not starting driver ‘uc_roon_driver’: no configured instances
2026-01-09 12:18:45.891304 +00:00	core	NOTICE	Not starting driver ‘uc_sonos_driver’: no configured instances
2026-01-09 12:18:45.879030 +00:00	core	ERROR	[uc_appletv_driver] Error connecting to driver ws://127.0.0.1:8097: ServiceUnavailable(“Failed to connect to host: Connection refused (os error 111)”)
2026-01-09 12:18:45.872787 +00:00	core	NOTICE	Not starting driver ‘uc_hue_driver’: no configured instances
2026-01-09 12:18:45.771380 +00:00	core	NOTICE	  uccore : PWD=/opt/uc/data ; USER=root ; COMMAND=/usr/sbin/wl band auto
2026-01-09 12:18:45.769956 +00:00	core	NOTICE	  uccore : PWD=/opt/uc/data ; USER=root ; COMMAND=/usr/bin/systemctl start btstack
2026-01-09 12:18:45.756728 +00:00	core	NOTICE	  uccore : PWD=/opt/uc/data ; USER=root ; COMMAND=/usr/bin/systemctl start wpa_supplicant
2026-01-09 12:18:45.747475 +00:00	core	NOTICE	  uccore : PWD=/opt/uc/data ; USER=root ; COMMAND=/usr/sbin/wl country US
2026-01-09 12:18:45.711628 +00:00	core	NOTICE	[custom-b9e17f] Reconnecting in: 500ms
2026-01-09 12:18:45.711136 +00:00	core	ERROR	[custom-b9e17f] Error connecting to dock ws://192.168.1.191/ws: ServiceUnavailable(“Failed to connect to host: Network is unreachable (os error 101)”)
2026-01-09 12:18:45.710120 +00:00	core	NOTICE	[custom-f06b11] Reconnecting in: 500ms
2026-01-09 12:18:45.709508 +00:00	core	ERROR	[custom-f06b11] Error connecting to dock ws://192.168.1.192/ws: ServiceUnavailable(“Failed to connect to host: Network is unreachable (os error 101)”)
2026-01-09 12:18:45.704706 +00:00	core	NOTICE	Created Dock IR emitter: dock_id=custom-f06b11, name=‘Unfolded Circle Dock (Cabinet)’, model=UCD3, active=true, port_mask=0
2026-01-09 12:18:45.704494 +00:00	core	NOTICE	[custom-f06b11] Resolved ws url: ws://192.168.1.192/ws
2026-01-09 12:18:45.704179 +00:00	core	NOTICE	Created Dock IR emitter: dock_id=custom-b9e17f, name=‘Unfolded Circle Charging Dock’, model=UCD3, active=true, port_mask=0
2026-01-09 12:18:45.700276 +00:00	core	NOTICE	[custom-b9e17f] Resolved ws url: ws://192.168.1.191/ws
2026-01-09 12:18:45.683518 +00:00	core	ERROR	Cannot connect to BT daemon: I/O error. Reconnecting in 643.497995ms
2026-01-09 12:18:45.672858 +00:00	core	NOTICE	Execute system command: StartBluetooth
2026-01-09 12:18:45.654789 +00:00	core	NOTICE	Updating BT service configuration file, connections=1
2026-01-09 12:18:45.642667 +00:00	core	NOTICE	Execute system command: StartWifi
2026-01-09 12:18:45.640905 +00:00	core	NOTICE	Execute system command: EnableWoWLAN(true)
2026-01-09 12:18:45.640517 +00:00	core	NOTICE	Execute system command: SetWifiBand(Auto)
2026-01-09 12:18:45.632329 +00:00	core	NOTICE	Microphone enabled: true
2026-01-09 12:18:45.629147 +00:00	core	NOTICE	Feature flag enabled: routable_if_link. Using operational state ‘routable’ for WiFi connect events.
2026-01-09 12:18:45.624146 +00:00	core	NOTICE	Monitoring network link ‘wlan0’ for changes
2026-01-09 12:18:45.573052 +00:00	core	NOTICE	Setting rgb button backlight to: (255, 255, 255)
2026-01-09 12:18:45.569623 +00:00	core	NOTICE	Execute system command: SetWlCommand(“country”, “US”)
2026-01-09 12:18:45.564292 +00:00	core	NOTICE	Enter normal mode: standby in 300s
2026-01-09 12:18:45.296347 +00:00	core	NOTICE	starting service: “actix-web-service-127.0.0.1:9000”, workers: 1, listening on: 127.0.0.1:9000
2026-01-09 12:18:45.296044 +00:00	core	NOTICE	Actix runtime found; starting in Actix runtime
2026-01-09 12:18:45.241959 +00:00	core	NOTICE	Feature flag enabled: routable_if_link. Using operational state ‘routable’ for WiFi connect events.
2026-01-09 12:18:45.122870 +00:00	core	NOTICE	[Voice] Connected successfully
2026-01-09 12:18:44.865329 +00:00	core	NOTICE	starting 1 workers
2026-01-09 12:18:44.315290 +00:00	core	NOTICE	Cleaning up downloaded system OTA updates <= 2.8.1
2026-01-09 12:18:44.295312 +00:00	core	NOTICE	Core-API listening on: 127.0.0.1:9000
