Connection to dock not established
when I’m not using the remote for approximately 10 minutes and I want to use it again I always get the error “connection to dock not established”. After waiting for around 5 seconds it’s working normally again. That’s quite annoying when I , for example, have to mute the tv because of an incoming call.
Is this a known problem?
The remote goes to sleep when it’s not in the dock after a specific time which can be set within the web configurator (max 30 minutes). After waking up it tries to reconnect to the Wi-Fi network.
In a future update you will be able to prevent this behavior when an activity is running but this will impact battery life.
Thank you for the answer.
Somehow I have the feeling that this behavior occurred after an update but maybe I’m wrong.
