I’m very happy with my ucr2, so far.
I have invested a significant amount of my most precious ressource (time) in learning remote codes and configuring macros and activities.
Is there a way to backup and restore my configuration?
I know, I can export my custom learned codes, but that is less than half of the way…
Almost exactly one year ago Marton said on Discord they have a backup/restore function in their plan. But currently this is not even on the roadmap.
I also agree that this is a crucial function especially since everything is stored locally. If your remote gets broken or lost you have to manually reconfigure everything besides the ir codes if you exported them.
I have looked at the documentation of the Rest API and there is at least a function to read the configuration via a HTTP GET request (/cfg). But restoring the configuration seems to work only per single sub-category and not for all at once.
Edit: But this seems to be a missing function at least according to the description of this API preview on GitHub. Unfortunately there is also no GitHub issue to check the current status.
