Community Integration - Sony Projectors (ADCP for newer models)
As I can’t edit the thread for the older SonySDCP integration I created a new one for the newer and improved SonyADCP integration.
This integration should be used for Sony home cinema projectors that have been release since 2016. It suports to control multiple devices at the same time and sending native ADCP commands via the remote entity e.g. to send commands that are not exposed as simple commands or set a specific value of a setting.
There’s a new 1.2.0 release that adds new sensors for temperature, system status and video signal infos. Video signal infos will also be displayed in the media widget Release v1.2.0 · kennymc-c/ucr-integration-sonyADCP · GitHub
New release including support for 20 select entities (depending on the model), 2 new sensors and commands and other fixes: Release v1.5.0 · kennymc-c/ucr-integration-sonyADCP · GitHub
New version with support for custom display names for picture position presets: Release v1.5.1 · kennymc-c/ucr-integration-sonyADCP · GitHub
New release which adds German language support: Release v1.6.0 · kennymc-c/ucr-integration-sonyADCP · GitHub
New release which fixes some bugs and adds new entities for blanking: Release v1.6.1 · kennymc-c/ucr-integration-sonyADCP · GitHub
