Codes for Arris VIP5242W set-box? Movistar UDH
I was finally able to configure the remote using Home Assistant , a lot of script (one per button) and the Harmony Hub. Therefore, I will not be returning the remote and dock…
I hope that in the future the remote can be captured natively, so I don’t have to use the Harmony and Smart Home hub.
Finally I learned the codes using a iTach Wired TCP/IP to IR, and here are the. codes Unfolded codes – Google Drive
