I can control my projector with one of the IR eyes connected to the dock; but the projector is on the ceiling and to tug the cable away I would need to extend it by 5 to 6 meters. Can I simply use a 2.5mm jack extension cable on the infrared cable?
I read about the IR signals being weak so was wondering if an extension cable would degrade the signal or, since it’s just a led at the end of a powercable, would extending it not influence the signal strength?
Greetings<
Ivo
