I’m currently running Beta 1.8.0 so I could try the Bluetooth integration. It works great.
I’d like to upgrade so I can try the Community LG integration.
If I go up to 1.9.4, can I load the integration to the remote without having to run a separate hosting computer?
You can also use the WebInterface. Log into the WebInterface, enter PIN and go back one step to see this again:
now choose core-api rest and scroll down until you see
When a stable firmware will be released you can also use the web configurator to upload the file. The current beta firmwares are aimed at developers to optimize their integrations.
Yes, the instructions are helpful. Looking forward to a Harmony configured tar.gz for direct, without anyone saying this is just for developers ad nauseum. The developer there has done herculean efforts to containerize, etc but hoping for on remote.
