Hi, Any idea about the weird problem?
I am using home assitant integration, (with harmony hub) where I create some “script” to control an “original remote buttons”.
I Added them works fine into web configurator, in some macros, and also the buttons directly added to the remote.
After some time of inactivity (some hours) the buttons stops working from the remote, and appears as “disconnected” in the web configurator, but when I press in the “play button” to test them, they still works, but not in the remote
… the most weird thing is that all the macros that includes this buttons “works all the time”.
After rebooting the remote everything works fine, after the next “safe power situation”, where the buttons stop working, but macros and in web configuration works all the time.
This is happening in the stable and beta firmware.
I try to “solve” this situation creating a “macro” for each button, now it works all the time (showing the information on screen when is executing), but it’s not posible tu use this “trick” for number pad, because is not posible “press” to consecutive “macros”, for channel “10” for example, when you press “number 1” it no posible to press “0” until the “info label” dissapears, when the “channel 1” is just loaded.
Thanks in advance
