Button brightness
even at the brightest setting it is very difficult in a dark room to see the buttons. Anyone else? If so I hope they have a software update coming that can increase it.
For me the button brightness is also to low. Same with sound and haptic. But I think they won’t change this. Because of power compsumtion.
your suppose to be able to change the color of the backgournd light on the buttons. I know that is a feature they are working on. Hopefully they will also increase the brightness as well
Your right. You can change the color and brightness of the buttons in the web-editor by settings and display. But indeed 100% is still to low.
