Boulder 866 USB Remote
Anybody had any luck adding a generic USB remote? I’m trying to control my Boulder 866 with the R3. Problem is, the 866 can only be controlled via the Boulder App or with a chintzy USB remote.
FWIW, I have an actual Nvidia Shield Pro Remote and it doesn’t control the 866 at all. It would be nice as I can use the Roon integration with 866, but I don’t have volume control so I need two remotes which is a pain in the ass.
Kevin T
