Anyone with a Beyonwiz T4 have a working IR Codeset they could recommend?
A quick Google search led me to the Beyonwiz forums, give this a go.
Thank you muchly.
I have added POWER_TOOGLE to my codeset , updated all instances that had the original POWER mapped to POWER_TOOGLE using the same HEX CODE and now when in the Beyonwiz Remote screen pressing the power button says “No data found”. I tried restarting everything but the issue persists. Any thoughts appreciated.
I resolved in a very convoluted way. I deleted the Remote and the DB info. I then reinstalled the backup of the Remote and then had to add it back to all Activities and map all the buttons again. Seems like a lot of work to change the name of a single codeset entry from POWER to POWER_TOOGLE
