BBC iPlayer on android tv integration
Appreciate that this is a Sony problem, I can’t seem to find a way to open “BBC iPlayer”, on android tv integration.It doesn’t seem to use the Google playstore version of the app?.Has anyone found a workaround?
Try com.sony.dtv.sonyselect-iPlayer
On Discord @thebatfink published a Sony TV custom entity configuration for the requests integration (Discord).
Can someone download it for me to test? I’m not registered there.
Thank you all
