Bang & Olufsen Beosound 9000
Anyone have B&O Beosound 9000 successfully controlled?
Apparently dock does not want to learn Beo 4 so a bit lost of options. Harmony does it just fine so it should not be impossible?
All ideas are welcome!
Works fine through HA and Harmony, not the most streamlined solution but it works. Snappy and everything.
Straight IR would be preferred of course.
You can find the exact ir code set on
https://irdb.globalcache.com/Home/Database
Don’t know if they work
They don’t, unfortunately. This might be a HW-issue too so I think I’m fine with R2 → HA → Harmony → B&O for now.
You mean they won’t work, right?
Ok, than you have to go the long way.
