Does anyone have the IR codes for the AWOL Vision projector (CSV file for the Remote 3)? The codes are available in the Logitech IR code database, even though the Harmony hasn’t been supported for a while. Or is it possible to export the IR codes from the Harmony? Unfortunately, you cannot learn the IR codes of the awol vision remote control with the remote 3 dock.
Harmony doesn’t allow you to export ir codes. Usally you find a lot of codes in Global Caché’s database (Database | Global Caché Control Tower) but Awol is not listed as a brand name there. Maybe there are identical models by other manufactures or the company is known to use different names for specific areas around the world?
If you can’t learn the codes they could be in an unsupported format. This could also result in problems when importing them from a file as the remote can only send supported ir formats. There was another device that had this issue and the manufature was using a very uncommon and outdated ir protocol. These issues should be resolved when the raw ir learning feature is implemented but there has been no timeframe give by UC.
I know it has been a bit, but here is what I have for my AWOL Vision LTV-3000 Pro. This includes discrete on/off commands that I had to hunt down and use AI to help me reverse engineer how these work with the R3, but they are working great for me.
“key”,“format”,“code”
“VolumeUp”,“HEX”,“3;0x7350AF;32;0”
“VolumeDown”,“HEX”,“3;0x73D02F;32;0”
“Mute”,“HEX”,“3;0x73D827;32;0”
“Menu”,“HEX”,“3;0x73F00F;32;0”
“Back”,“HEX”,“3;0x733AC5;32;0”
“ArrowDown”,“HEX”,“3;0x611F649B;32;0”
“ArrowUp”,“HEX”,“3;0x611FA45B;32;0”
“ArrowLeft”,“HEX”,“3;0x611FE41B;32;0”
“ArrowRight”,“HEX”,“3;0x611F14EB;32;0”
“OK”,“HEX”,“3;0x611FD42B;32;0”
“Picture”,“HEX”,“3;0x73BE41;32;0”
“Input”,“HEX”,“3;0x7348B7;32;0”
“InputNext”,“HEX”,“3;0x73A45B;32;0”
“InputPrevious”,“HEX”,“3;0x7324DB;32;0”
“InputSelect”,“HEX”,“3;0x7314EB;32;0”
“Home”,“HEX”,“3;0x73DA25;32;0”
“POWER_ON”,“HEX”,“3;0xB3B847;32;0”
“POWER_OFF”,“HEX”,“3;0xB338C7;32;0”
“POWER_TOGGLE”,“HEX”,“3;0x7358A7;32;0”
Thanks. They work fine! Great!
Do you also have IR codes for Input HDMI1-HDMI3?
Rad. And I don’t! I looked high and low but don’t think there are discrete HDMI commands. If I ever find some I will share here.
Thanks to the custom integration by @kennymc.c (http/get/post…), I found a solution for the HDMIx input.
Install the custom integration (GitHub - kennymc-c/ucr2-integration-requests: A network multi tool integration for Unfolded Circle remote devices) and complete the setup
Select “text over TCP”
In the user interface or in a sequence, enter the command as “text over TCP”
Then, enter the following in the source field:
For INPUT HDMI1: 192.168.178.xxx:4352,“%2INPT 31\r”
For INPUT HDMI2: 192.168.178.xxx:4352,“%2INPT 32\r”
For INPUT HDMI3: 192.168.178.xxx:4352,“%2INPT 33\r”
(192.168.178.xxx = IP address of the AWOL projector)
The AWOL LTV-3000 projector must, of course, be turned on and ready.
For me, it takes about 45 seconds. (Keep this in mind in the sequence when powering it on — Delay: 45000)
I have been trying to figure out how to reliably control my LTV-3500 forever! Thanks for figuring it out! Can’t wait to try it out when I’m home from work!
Oh, I just noticed that there doesn’t appear to be a code for the “Settings” button. Do you have the code for that, by any chance @obliojoe ?
Nevermind! It appears that the LTV-3500 doesn’t support any of the IR codes with the exception of the power codes. Still, very helpful as I can control everything else via BT.
