Awesome blaster
Hi, not a question but just a post because I’m happy.
With Harmony I used 2 power plugs: one for charging remote and one hub that emitted IR in a closed cabinet.
Now, I just use one dock that charges the remote and from that dock have 10m extension cable to the cabinet, plugged in the IR blaster and all works well! Just happy to not need a second powerplug anymore.
It just took me a while to remember that you have to first plugin the IR blaster and only then power up the dock otherwise no IR is transmitted.
When the ‘keep wifi on’ becomes available for R3 it would make it almost perfect! I hope that fix becomes available soon.
Great job UC team!
