Arris VIP5662W Codes
Like the codes for Arris VIP5662W
Can you direct me to codes/integration for the Arris VIP5662W?
Please see my post on ‘KPN settopbox Arris 5202’. - maybe these codes will work for you…
I have added the codes and have the device on my remote. I do not know how to add it as an integration. Can anyone help?
A device is an entity not an integration. If you want it shown on the remote you must go to customize your remote and add the entity. Better would be create an activity with this device and add activity to your remote.
The codes did not work on the Arris VIP5662W. Has anyone been able to add this device? Without it, the remote is useless to me. The Arris is my cable TV box.
There is an Arris “VIP5662W 4K IPTV Receiver” entry in the Global Cache IR Code database here: Database | Global Caché Control Tower
I go to that site. While it recognizes “Arris” and that it is a “Set Top Box”, it does allow me to select the model. I am registered and verified for the site. Are you able to share the codes?
I was able to select the model number and was sent the codes. I’ve edited to correctly format them for upload if you cut and paste them into notepad or something similar and save as a .csv file. Good luck.
| key, code
APPS,0000 006D 0000 000E 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 000C 000C 000C 000C 000C 000C 000C 000C 000C 0D36
BACK/EXIT,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 000C 000C 000C 000C 0018 0018 0018 000C 0D36
CHANNEL DOWN,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 0018 000C 000C 0018 0018 0D42
CHANNEL UP,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 0018 0018 000C 000C 0018 0D42
CURSOR DOWN,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 000C 000C 0018 0018 0018 000C 0D36
CURSOR ENTER,0000 006D 0000 000E 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 000C 000C 000C 000C 000C 000C 0018 000C 0D36
CURSOR LEFT,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 000C 000C 000C 000C 0018 0018 0D42
CURSOR RIGHT,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 000C 000C 000C 000C 000C 000C 0018 0D42
CURSOR UP,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 000C 000C 0018 000C 000C 0018 0D42
DIGIT 0,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0D42
DIGIT 1,0000 006D 0000 000E 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 000C 000C 000C 000C 0018 0018 000C 0D36
DIGIT 2,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 000C 000C 0018 0018 0018 0D42
DIGIT 3,0000 006D 0000 000E 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 000C 000C 0018 000C 000C 0018 000C 0D36
DIGIT 4,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 0018 0018 000C 000C 0018 0D42
DIGIT 5,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 0018 0018 0018 0018 000C 0D36
DIGIT 6,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 0018 000C 000C 0018 0018 0D42
DIGIT 7,0000 006D 0000 000E 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 0018 000C 000C 000C 000C 0018 000C 0D36
DIGIT 8,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 0018 000C 000C 000C 000C 0018 0D42
DIGIT 9,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 0018 000C 000C 0018 0018 000C 0D36
FORWARD,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 000C 000C 000C 000C 0018 000C 000C 0018 000C 0D36
GUIDE,0000 006D 0000 000E 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 000C 000C 000C 000C 000C 000C 000C 000C 0018 000C 0D36
INFO,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 000C 0D36
MENU DVR,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 000C 000C 0018 000C 000C 0018 0018 0D42
MENU MAIN,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 0018 000C 000C 0018 0018 0018 000C 0D36
MUTE TOGGLE,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 0018 0018 000C 000C 0018 0018 000C 0D36
OPTIONS,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 0018 0018 0018 000C 000C 0018 000C 0D36
PLAY PAUSE TOGGLE,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 000C 000C 0018 0018 000C 000C 0018 000C 0D36
POWER TOGGLE,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 000C 000C 0018 000C 0D36
PREVIOUS CHANNEL,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 000C 000C 0018 000C 000C 000C 000C 0018 0D42
RECORD,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 000C 000C 000C 000C 0018 000C 000C 0018 0D42
REPLAY,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 000C 000C 000C 000C 000C 000C 0018 0018 000C 0D36
REVERSE,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0D42
SEARCH,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 000C 000C 0018 0018 000C 000C 000C 000C 000C 000C 0D42
SKIP,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 0018 000C 000C 0018 0018 000C 000C 0018 0D42
STOP,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 000C 000C 0018 0018 0018 0018 0D42
VIDEO ON DEMAND,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 0018 000C 000C 0018 0018 000C 000C 0018 0018 0D42
VOLUME DOWN,0000 006D 0000 000C 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 0018 0018 0018 0018 000C 0D36
VOLUME UP,0000 006D 0000 000D 000C 000C 000C 0018 0018 0018 000C 000C 000C 000C 0018 0018 0018 0018 000C 000C 0018 0018 000C 000C 0018 000C 000C 0018 000C 0D36
Let me try that cut and paste again as I noticed issues with the previous one. Global Cache has these for the model number: Arris VIP5662W 4K IPTV Receiver - Set #: 6184
key, code
