I cannot, for the life of me, get my AppleTV integration to work. In the logs I continuously get:
Could not connect: Failed to set up remote control channel
I do have a four digit Airplay password set which I use when setting up the integration. The AppleTV is hard wired, and has a static IP. My Dock 3 is wifi and seems to be on 2.4Ghz.
Any ideas?
