My Remote 2 has stopped working with Apple TV. The device appears in grey on my home screen and if I try and select I simply get the error “Apple TV is unavailable”. I have updated both my Apple TV and Remote 2 to latest firmware and issue still persists. Turning off home network and remote makes no difference.
Does anyone know what may be causing the issue and how to resolve?
Have you tried to run the integration setup again?
With tvOS 18 there were reports that the MAC address the Apple TV is advertising through the control protocols has changed. The Mac address ist also used for the entity id on the remote and therefore the remote can’t find the device anymore.
Thank you, both for the suggestion and the additional background information. I had stopped working a while ago but had not taken the time to troubleshoot properly. I just removed and reinstalled integration and it is now working.
Yes 2.x are beta. I asked because I have a similar problem with another integration which is always unavailable after restart of remote. I thought it might be the same reason.
