Apple TV pin not showing up for tvOS 27 + Control multiple Apple TVs
Hi All,
I tried to connect my UC3 to Apple TV that’s on tvOS 27. When the remote expects a code on the screen, I don’t actually see a code on the screen.
i tried connecting to my other Apple TV that’s on older sw rev and it connected fine. Now I noticed that I can’t add multiple Apple TVs to the UC3 - is that expected?
Have checked your airplay settings on the ATV? Did you gave each ATV a unique name? It should work with more than 1 ATV.
This is known issue with tvOS 27 Beta: tvOS 27 beta: AirPlay pairing does not show PIN on Apple TV 4K gen 3 · Issue #2866 · postlund/pyatv · GitHub
Beta versions shouldn’t be used in a productive enviornment. Always check if there are known issue with the version you want to install before updating. As tvOS 27 is still beta it’s unlikely this will be fixed before a public release.
