Apple TV integration stopped working
My Apple TV integration stopped working. Tried re-adding it but still not working. Did something change? It says Service Unavailable in a red banner on top of the screen when I try to send button presses.
Same here. Been dealing with it for weeks. Have partial control via Home Assistant but the UC integration stopped working and won’t reinstall/configure.
Did you get an update for ATV and what firmware on R2 do you use? I think ATV got 18.4 a few weeks ago and there was a change.
Yes I think it happened on an update. What is the latest firmware available for Remote 2? The Apple TV integration I have is 0.14.1 but on the Github there is a new version 0.18.1, can I manually update the integration somehow?
They latest integration is not yet in a firmware. You only get the latest versions with the beta firmware which it 2.4.5 now.
I installed the latest Beta firmware and everything is working again.
