Apple TV integration - commands missing
Hello,
I’ve recently created an activity for watching my Apple TV. After successfully adding the Apple TV & Denon AVR integrations.
However when I’m in the web configurator, in my activity, I’m trying to map some commands for buttons, but I cannot seem to find the “control center” command for the Apple TV…the integration readme lists it as a supported command.
But I cannot seem to find it under button mapping …all sorts of commands are listed…but not “control center”
Am I missing something or doing something wrong?
Thx :folded_hands:
I have no ATV anymore but from the source I would try menu from the media player entity:
case media_player.Commands.MENU:
res = await device.control_center()
Try the MENU command.
Thank you :folded_hands:
That sorted it…I was beside myself trying to find it.
Cheers!
