Hello, I mapped the Home ATV command to a button and it takes me back to ATV Home Screen, I tried using the same command in my Activity start sequence and it leaves the current ATV app on screen. Any suggestions?
Could be a timing problem. Did you try to put a delay after powering on the system?
Thanks for that, the 2 sec delay I had was the issue. I kept incrementing up and 5 sec is the magic number.
