Apple TV Buttons
Ever since the last two beta updates, for some reason I have lost the button mapping of Select, or OK whichever you want to call them. I can navigate left, right, up, down etc, but hit OK and absolutely nothing happens. Its the same with Pause/Play. Is no one else experiencing these things as I have searched, and searched for a similar issue without success. Any tips/solution appreciated.
Are you talking about the Apple TV media player and remote entities? I don’t have any problems with them. Otherwise in activities you have to do the mapping yourself.
Yeah I’d performed the mapping in the activities but they just aren’t doing anything. :man_shrugging:Rebooted just in case, removed the mapping, re-added them, still nothing. Very puzzling not to mention annoying having to dig out another remote to use.
Do you see any errors on the remote? Can you post a screenshot of you mapping with the command names shown and logs of the remote interface, core and Apple TV integration right after this happended? You can download them under settings/development/logs
I’ll have a check. There’s no feedback at all, simply does nothing. Might give it reset and restore, see if that helps. It’s clearly not a common issue it seems :+1:
Solved it!! I would have never looked for “Cursor Enter” I was looking for Select, or OK. Deff a Brit issue :+1: But thank you very much @kennymc.c :+1::+1:
