Apple-TV and activity
No! I simply mean you cannot install Apple TV integration as it is part of the firmware. Simply go to entities, click on + and scroll down to Apple TV then you can add an Apple TV again. You cannot change or update the integration itself.
btw. If you have some kind of stable situation make a BACKUP!
Hi there. Does anybody know how to adjust the media widget properly? As long as I have it fullscreen, its fine. But if I make it smaller, the artwork is cut.
Is there a trick I’m missing?
Thanks Chris
Thanks Ralf. I have made numerous backups but unfortunately I have not yet been able to have everything working.
So it is not working
What is not working?
It looks like it may be now. Have to try configuring
Supposedly for the AppleTV command ‘Input source” clicking in the source field is supposed to show a list of options (Netflix, Disney+, etc)
I don’t see a list
Ok there are several complains also on Discord, which is the best source for information and help concerning the R3. Try simply entering Netflix in the source line.
When I still had an Apple TV the list worked but I was on 18.something.
If you are interested http://unfolded.chat/
opened the chat window after dismissing the error. Not sure where to go from there
I am not sure how it works on a PC or Apple. I use my tablet but there is a discord App/program for Windows which I use in the office.
