App for Philips TV Titan OS
to use my Philips 77OLED759/12 with Titan OS, i have create a App for the Remote3 (Custom Integration) by ChatGPT. For me it works well and if someone is interested, i dont want to keep the benefits for myself.
U can visit: daCream87/uc-philips-titanos: Philips Titan OS Integration for Unfolded Circle Remote 3
So, have fun with it!
Oliver
tested with Philips 77OLED759/12
Are you also planning to release custom integration tar.gz archives for both of your projects? So far it looks like there hasn’t been any release published but you seem to have build the archives through your GitHub action.
thanks for your feedback. I have added a Release Page on the GitHub, so u can download the archive for the integration.
Also for the SyncBox app.
If u have any comment or find a problem, let me know and i will check and fix it!
Unfortunately I don’t own a Philips TV :sweat_smile: But if you want more feedback you should also post your integrations on the UC Discord server in community-projects.
