Any recommendation for power adapter
Any recommendation for power adapter for circle 3?
I use one of these for the dock
I bought the “Samsung Galaxy 25W Power Adapter excluding cable USB-C to USB-C” because that delivers 3A. The dock requires at least 2.5A, so be careful to buy a charger that delivers at least that. The dock does not need more than 25W.
I use Ugreen 15W with 3A.
The ‘UGREEN Nexode 3-Port Fast Charger 65W’ works well for me. It provides 5V/3A.
Avoid the following, as they cause a hissing sound on the Dock 3 (though they also provide 5V/3A):
  • UGREEN Nexode 1-Port GaN II 30W
  • Aukey Omnia II 1-Port 30W (PA-B1L)
