Anthem Integration - No Data
I installed the GitHub - mase1981/uc-intg-anthemav integration to use with my AVM90. Once installed I added it to one of my rooms. However when I tap on it I get a message in a red banner at the top of the remote that says No Data Found. Not sure what I am doing wrong. I can control the AVM90 via a web browser successfully. When I setup the integration in the web configurator I used the same address and port that I saw in the network info of the AVM 90. Any ideas are appreciated.
Share integration logs (also, easier to communicate on discord and share the logs there in the Anthem integration channel). Share logs, without logs no way to know what is happening on the background. if you don’t know how to share logs, go to the remote settings via web configuration, development, logs, drop down and choose the anthem integration, download. but download after replicating the issue and stating the timestamp you replicated the issue and share the logs for review.
Thank you will do later today.
I captured the logs but I can’t seem to find the Anthem integration channel in the list on discord. Can you help me locate it so I can upload the log. There doesn’t seem to be any way to upload the logs here.
Rob
All integrations are here. Just search for anthem
