Ja es funktioniert ja,kann alles bedienen.
Ich wollte nur wissen,warum es durch gestrichen ist?
Please use a translator and post English.
I just wanted to know why the generated entities are crossed out in red?
it is absoloutely impossible to answer that question without more information,
which version are you using? are they showing red meaning unavaialble but do they work or dont work? share the logs, this is vauge information which is impossible to answer that question .
The red lines are gone. It now says "currently unavailable."
The device is fully functional and responds. Everything is fine.
Version 1.12
Can’t help with no logs
I'm new here, sorry. Where can I find the protocols?
Guten Morgen
Die Anthem Integration funktioniert jetzt soweit,bis auf ein paar Befehle.
Volume Regler finde ich irgendwie nicht.
Und seit der neuesten Version,geht das Display an,wenn ich die R3 in die Hand nehme.
Bei wem noch?
Danke
Good morning
The Anthem integration works now, except for a few commands.
I can’t find a volume controller.
And since the latest version, the display turns on when I take the R3 in my hand.
With whom else?
Thank you
Why are the volume up/down controls missing?
Am I missing something?
uninstall and re install. they are there, confirmed by multiple users.
