Anthem AVM 70 intergration?
Anyone know where I can get Integration for the above?
Not all devices have integrations (yet), but can still be controlled by infrared.
To add the Athem infrared:
Entities > Add new > Add new infrared device > next > Manufacturer name = Anthem > Device = generic AVR
This will load a generic Anthem AVR infrared dataset to control your Athem.
Should this built-in dataset not work, you’ll have to create a custom dataset from Global Caché
Create Account > Database > Search
Verified users can get the full dataset at once. Registered users can download individual commands you have to enter seperately:
Copy everything behind hex code 1
On the remote:
Entities > Add new IR device > Create Blank > Add infrared code data set (+) > Paste the code as a pronto code and give the command a name.
Rinse. Repeat. For all the codes.
This way you can get any ir remote to work.
In addition to IR, there’s also a very solid Anthem integration for Home Assistant, if you’re using that. It’s a really nice sidecar for the UC remotes while more integrations come online.
Having been using the Remote Two for a year and a half and now the Remote 3, as the hardware lands in more hands, more folks are creating community integrations for devices like these, so it’s only a matter of time.
Or download full IR dataset from Anthem.
Have an MRX540, and I just copied from their excel function and pronto classic collumn (main zone only) to a new sheet, and then to notepad, replaced tab to ‘,’ and saved to text file and changed extension to csv. Then imported.
