So I can add the Anthem AVM 60 IR remote, but it only gives me Generic AV1 as an option and that doesn’t seem to work. I tried teaching codes to the Remote Two Dock, but so far no luck. I just get a flashing red light from the dock. I then found the remote codes posted on Anthem’s website. I tried to enter the codes manually as both Hex & Pronto and it doesn’t seem to work either way.
The codes are here:
https://www.anthemav.com/downloads/AVM60-MRXx20-IR-hex.xlsx
Maybe I just don’t know what I’m looking at, but I assume the Hex Code for ON is:
0000 006D 0022 0002 0155 00AA 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 05ED 0155 0055 0015 0E47
Kevin T
