How do you guys control Android TV? I have a challenge to power on a sequence that includes Nvidia Shield. Harmony based switch on works perfect using Bluetooth based Integration. Unfolded Circle IP/API based approach does not see Shield as active most of the time for switch on. After it is switched on then controls work well.
I am still struggling to replace Harmony with Unfolded Circle completely…
Not with the current SW state… Would be curious to hear your experience, maybe the issue is just with my setup.
I have high hopes for Bluetooth support feature which should be still released this year as this is the current approach Harmony uses.
