Android TV Integration - Connection Refused
Hi all,
I’m having trouble adding the Android TV integration for my Nvidia Shield TV Pro (2019).
I add an integration then select Android TV. I then enter the IP address of the Shield and I can select my “SHIELD Android TV”, but then I get a “CONNECTION_REFUSED” error each time.
Is anybody able to steer me in the right direction as to what is causing the error? Are there any settings on the Shield itself that need to be changed?
Any guidance/assistance is much appreciated. Thanks in advance!
Not sure what changed in the last 48 hours, decided to try again today and it’s now working.
Please disregard. Thank you!
