Android Bell Fibe App commands
I’ve got Bell Fibe and thankfully that’s just an Android TV box, I’ve got it set up as an Android TV entity but am unable to map things like the Netflix or Crave buttons and the Google Assistant search/mic doesn’t seem to have a link. Has anyone set these up or will this require trying to figure out the code?
Thanks for any tips.
App can be started with the input source command. Some popular apps are already defined for others a source like
market://launch?id=org.xbmc.kodi
Must be used. Were you have to put the app id at the end.
Mic not yet active.
Awesome thanks for confirming appreciate the help.
Matt
Hello @commonperson ,
I also have the Bell Fibe Box.
How did you set it up? What were the steps?
I cannot seem to get my remote to detect the bell fibe box.
Thanks.
