Allente 1, KAON BCM72180 PVR
What´s left to do?
I have in my setup one satellite reciever as in the header. It´s Android powered so I was thrilled to see that it was possible to merge that entity in integrations.
But… As an integration it really not show up as all the other remotes, and all commands are not functional. Apart from that several commands are missing as digits for example.
So, I just learned all codes from the remote. It all went smooth. But they do not work, even though the set-top box seem to react with the light at its front.
I have tried different Kaon codes from GlobalHeadache but none of them are working. Are there any Scandinavian people here that have solved this? I really don´t know what to try next…
So.
Here are the learned codes:
Custom - learned IR codes,Satellite,Digit_1,HEX,3 0x6170807F
Custom - learned IR codes,Satellite,Digit_2,HEX,3
0x617040BF
Custom - learned IR codes,Satellite,Digit_3,HEX,3 0x6170C03F
Custom - learned IR codes,Satellite,Digit_4,HEX,3
0x617020DF
Custom - learned IR codes,Satellite,Digit_5,HEX,3 0x6170A05F
Custom - learned IR codes,Satellite,Digit_6,HEX,3
0x6170609F
Custom - learned IR codes,Satellite,Digit_7,HEX,3 0x6170E01F
Custom - learned IR codes,Satellite,Digit_8,HEX,3
0x617010EF
Custom - learned IR codes,Satellite,Digit_9,HEX,3 0x6170906F
Custom - learned IR codes,Satellite,Digit_0,HEX,3
0x617000FF
Custom - learned IR codes,Satellite,On/Off,HEX,3 0x617048B7
Custom - learned IR codes,Satellite,Menu,HEX,3
0x617054AB
Custom - learned IR codes,Satellite,Cursor_up,HEX,3 0x6170D02F
Custom - learned IR codes,Satellite,Cursor_down,HEX,3
0x617030CF
Custom - learned IR codes,Satellite,Cursor_left,HEX,3 0x6170D827
Custom - learned IR codes,Satellite,Cursor_right,HEX,3
0x617038C7
Custom - learned IR codes,Satellite,OK,HEX,3 0x6170A857
Custom - learned IR codes,Satellite,Back,HEX,3
0x617028D7
Custom - learned IR codes,Satellite,Play/Pause,HEX,3 0x6170C43B
Custom - learned IR codes,Satellite,Rec,HEX,3
0x6170847B
Custom - learned IR codes,Satellite,Volume_up,HEX,3 0x6170B04F
Custom - learned IR codes,Satellite,Volume_down,HEX,3
0x6170708F
Custom - learned IR codes,Satellite,Channel_up,HEX,3 0x617008F7
Custom - learned IR codes,Satellite,Channel_down,HEX,3
0x617058A7
And (for example) digit four looks like this in the Web configurator:
This might help someone help me? :smiley:
So, I´ve learned that the Kaon set-top box can be handled by Technicolor S70CDS codes. So it might be double format capable.
Too bad I can´t seem to get a hold of the ir-codes online.
Hello,
Interesting. Are you saying that the Allente 1 box can be controlled using IR? I thought that the remote control only used bluetooth.
I Will have the box and the remote control in different roms (15 m apart) and I have looked at ways of extending the range. No conclusion yet.
Nope, it can’t. Sorry.
Still waiting for UC to turn on BT…
Is the box Android or AndroidTV. Sounds similar but is not the same. For AndroidTV the digits, and more, are coming with the next firmware release but the are already in the current beta firmware 0.7.10.
It is Android TV. Well Ralf, you made me happy with that information! I think I´ll wat until the next “stable” release of firmware.
" Beta Firmware Update Disclaimer
By enabling beta firmware updates, you acknowledge and accept the following:
  1. Data Loss and Factory Reset.
    Beta firmware updates may result in data loss and necessitate a factory reset of your device. It is recommended to back up all essential data before proceeding with beta firmware installation.
  2. Use at Your Own Risk.
    Beta firmware updates may contain bugs and unfinished or unstable features. We advise against installing beta software on devices used daily."
Yes there is a little risk but the UC has the very nice feature of backup and restore which you should use. I already used it several times.
My other remotes do not have it and it can be a pain.
Maybe I’ll try that. Speaking of witch isn’t it long overdue for a new firmware?
So, there the new firmware arrived and is installed since release.
I deleted the old Android TV connection and made a new one.
It works exactly as before, what do I need to do to get the digits? Is that through the web configurator?
Here is the ir code for power toggle on Allente 1:
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
It is coming from the Harmony using codes for Canal Digital S70CDS (oneplace remote).
I have copied this command and the others to my Kramer Control system and they work absolutely fine
OMG, it actually worked!
Thank you very much! If it´s not too much of a problem, do you mind to share the digits 0-9 as well? That would make my R2 experience complete.
Hello again, glad that it worked.
I have done some work today so here are the 0-9 commands as well. Have not checked that they are OK but they should be.
1
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
2
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
3
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
4
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
5
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
6
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
7
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
8
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
9
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
0
0000 006e 0022 0002 0156 00af 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 066a 0156 0057 0016 0e18
Best
Dan
(this is my second attempt to send this message. Your system would not accept it)
This is absolutely awesome!
Thank you so much Dan, everything works like a charm. I’ve been searching endlessly online for this, and you came up with the solution.
I wish you the best of weekends. :+1:t2::+1:t2:
