Adding remote codes manually
I have so far pasted in 14 codes into settings for an entity. However when I go to assign them to button mapping I can only see 11 codes available to add as a short or long press option. Is this a bug in the web configurator or am I doing something wrong
I had this sometimes too, when I learned commands manually. Sometimes It helped, using the update/reload button of the browser and if not, the reboot of the remote helped.
Rebooting the remote appears to have solved the problem. Thanks for your advice.
