Adding Android TV fails
Adding my Philips Android TV unfortunately fails. It doesn’t show the 4 digit PIN on the TV and there are no options to select or change anything.
It correctly discovers the TV (and model) on the network but then fails with a timeout error.
My Alexa is happily paired with the TV and on the same network.
Since I can only put 1 image in the intial post, here is the discovery screen.
I have the same issue: Cannot add Android TV Integration · Issue #23 · unfoldedcircle/bug-reports · GitHub
Aha! Bug reports go on GitHub. Good to know :slight_smile:
Hi Guys,
I have a bug with the Android TV Integration also.
I cannot see a way to add multiple Android TV devices at once (both add to configured, but only one shows the code on screen to authenticate) and I don’t see a way to go back in the integration and reauthenticate or add another device.
Any ideas?
Have you try with new firmware 1.1.2, it seems to solve this issue
Hey @Dreaming! Thanks for letting me know. I tried it as soon as it came out and can confirm it works now!
