I’d wish there was an option to add graphics, and not just square icons, and also attach activity or macros to it.
You can assign activities or macros to the widgets. It will not help you to assign an activity because GUI and button mapping does not switch to the called activity. You must add the macro entity to the activity to use them. I have more than 70 macros I use in activities on the GUI.
It just feels somewhat limited to be locked to a grid.
I was looking to, for example, putting a continous border/line between my activities to keep it more separate. Things like that is impossible.
Even non-clickable - it would be great to add graphical objects, and beeing able to span it over several grids
Are you on discord? There was a tip: create a picture of 360x540 (I think it was this size) and split it into 24 squares. He used Adobe which seems to have such a splitter. This gives more possiblies but needs a bit of work.
