Acknowledge iR send with LED on Charging Base
Is it possible to have the option to get the charging base to acknowledge sending iR signal, with a flash from the built in RGB Led ?.
This could be selectable for those who do not want this in the remote configuration UI. Its only a small thing, but would at least provide a feedback that the iR command has been sent and transmitted from the charging base. Especial when trying to orientate the charging base to receiving device.
